LT1/LT4 Tech 1993-1997
Rocker studs breaking......
Old Sep 30, 2011 | 08:42 AM
davidkay's Avatar
Thanks everyone....... the push rod is fine and unbent. I cant check the spring bind as is seems the lifter must have shot out of its hole as the push rod drops into its hole too far after the stud broke and shot the rocker off, so I cant reassemble...... after reading all the advice and observing the rocker right before it broke (it was mvoing up and down much farther than the others) I think it must be a bad lifter and/or spring bind caused by a weakened or broken spring.. so I guess i begin taking off the manifiold to replace the lifter.
Old Sep 30, 2011 | 09:54 AM
davidkay's Avatar
thanks for all the help and advice.
Old Sep 30, 2011 | 10:41 AM
if the top of the lifter popped off it may have sent the valve into the piston.
Old Mar 5, 2012 | 09:41 AM
davidkay's Avatar
Thanks for all the advice, when we finally tore down the top of the engine it was a broken lifter!!
78 on my plate
May 4, 2012 11:50 AM
dan73159
Jul 5, 2010 07:18 PM
z28pete
Feb 26, 2008 01:24 PM
74_camaro
Mar 29, 2007 12:31 AM
