LT1/LT4 Tech 1993-1997
Reading codes?
Old Sep 4, 2012 | 08:57 AM
torque_is_good's Avatar
the scanner isn't going to tell you about the misfire
I have an actron 9145 and you can get the newer version too. GO to amazon.com and you'll find a deal
First you change the spark plugs and wires if they are old or questionable
that costs around $50
then fire her up. Does it miss when cold before open loop?
If not, does it miss when warm in closed loop? If so, then it's probably your O2 sensors and those are located in the collector of your headers (you aren't running stock exhaust are you)
if it does miss when cold, then it's not the ICM, it's probably not a cable and it probably is the opti.
But, check fuel pressure before jumping into the ignition just to either eliminate it or find that it's fuel related. I've not seen a bad fuel pump cause a "miss" however some folks misdiagnose an ignition miss with a stumble/stutter etc
Old Sep 4, 2012 | 09:28 AM
jkeaton's Avatar
Originally Posted by ryan88z
Jkeaton, is that the cb9145 model? I can't seem to find that one in the stores anymore
No, I got the CP9185. You won't find them in stores. Check ebay. Thats where I got mine for $120 and then the OBD1 adapter for another $30 from Amazon. It paid for itself the first time I used it.
https://camaroforums.com/forum/lt1-l...ks-94-a-71161/
v64thgen
Nov 2, 2019 01:41 AM
The Emperor
South West
Feb 18, 2012 11:07 AM
dogdog130
Dec 24, 2010 02:16 PM
warehimer33
Dec 22, 2010 07:16 AM
maudyZ28
Jun 19, 2010 11:41 AM
