LT1/LT4 Tech 1993-1997
rattling
Old May 12, 2010 | 12:46 AM
imcdowel's Avatar
Default rattling
i can hear a rattle from the front of the car. i can barely hear it when the hood is up. sounds like front left. its inconsistent in noise level but almost always there and sometimes significant. been doing it for a long time now, but getting worse... i think. what is it? thanks in advance.
Old May 12, 2010 | 12:31 PM
imcdowel's Avatar
like a piece of plastic rattling at high speeds at the very lower front of the car?
Old May 12, 2010 | 01:07 PM
whammer3024's Avatar
ROTM Winner
is your front air dam coming loose? there's a whole bunch of things it could be bro. i suggest you open the hood and start wiggling things around to see if anything is loose
Old May 12, 2010 | 03:49 PM
imcdowel's Avatar
oh boy sounds fun. ill see what i can find. do you think it could be bad? or just something small. i know the front bumper is a bit loose from my redo of half the car.
Old May 12, 2010 | 04:00 PM
18436572's Avatar
um just because it makes less noise with the hood up...
makes me thing hinges getting worn at the pins??? are the cylinders holding the hood up on thier own?
then ... there sure is alot that is in the front that could be loose, for sure try and snug up the bumper, even jam in wedges of paper/cardboard, tape, to try and isolate the noise.
look for signs of worn paint where something shows to be rubbing for clues
Old May 12, 2010 | 04:01 PM
Don't worry about it. Eventually whatever rattles will break, and then the noise will stop.
Old May 12, 2010 | 05:34 PM
imcdowel's Avatar
gee thanks pete. well its most likely a lifter. please entail what this means and what i have to do to fix it?
Old May 12, 2010 | 05:38 PM
lifter will make a ticking noise. how is the oil pressure?
Old May 12, 2010 | 05:51 PM
imcdowel's Avatar
well idk, the oil pressure gauge just goes ape. it dances around constantly never reading accurately. sometimes the ticking or rattling isnt as loud then sometimes its quite loud.
Old May 12, 2010 | 06:02 PM
what weight of oil are u using and what filter? also forgot what yr and motor?
