LT1/LT4 Tech 1993-1997
priming
Old May 23, 2010 | 09:47 PM
r6rider's Avatar
Default priming
im about done with my motor and was wondering if anyone knows how to prime the motor before start up.
Old May 23, 2010 | 11:22 PM
pump it? lol. need to have the intake off, take out the oil pump drive gear ( its where the distributor shaft would go down on a old sbc) u can use a long good sized screwdriver, cut off the end and put in a drill. or pick up a primer shaft set (way easier) and hook up drill to it. then u stick it down in the hole and line it up with the oil pump shaft slot to drive the pump. i primed mine before i put the motor in. i didnt see how i could get a drill under there once the motor was in. u can get a 90 elbow for a drill and do it that way.
Old May 23, 2010 | 11:32 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
You should be able to rent it.
This might help too...
http://www.348-409.com/fireup.html
Chevy101
May 31, 2013 11:47 AM
r6rider
Jul 15, 2010 07:38 PM
