LT1/LT4 Tech 1993-1997
oil priming problem
Old Jul 13, 2010 | 10:41 PM
r6rider's Avatar
Default oil priming problem
i got my motor all ready to be primed and i fire up the drill and get it goin but all it does is gargel and it seems no pressure is building up. i made the mistake of reverseing the drill and oil spilled out fro the oil housing. but what am i doin wrong that pressure isnt building up?
Old Jul 14, 2010 | 04:12 PM
better pull the pan and see if the pickup has come off. did you have it tacked on? i took the oil pressure sensor out till it shot oil all over. lol.
Old Jul 14, 2010 | 04:14 PM
did you do the remote oil filter? i had the hoses backwards and it wouldnt prime.
Old Jul 14, 2010 | 07:04 PM
r6rider's Avatar
no but im almost positive it wont come off cause it was hell gettin it on. the remote oil filter? whats that cause if it helps ill do it
Old Jul 14, 2010 | 07:30 PM
i moved my filter location, the headers where tight around it and didnt like the thought of trying to change the filter there.
so no oil is coming out the pressure sensor hole? are you turning it clockwise?
Old Jul 14, 2010 | 08:30 PM
r6rider's Avatar
im goin clockwise but nothin is comin out the pressure senser hole. do you think maybe i need a better drill with more power or i noticed on the tool to prime the pump that thier is a lose piece that i cant get into the hole cause the hole where the gear pump goes into is in the way. i didnt think that had anything to so with it tho
Old Jul 14, 2010 | 08:34 PM
pictures?
Old Jul 14, 2010 | 08:53 PM
r6rider's Avatar
ok so i got pressure to come out the pressure senser but my problem now is oil it coming out the top hole where the intake sits right next to on the back of the motor. what goes there?
Old Jul 14, 2010 | 09:47 PM
if your oil pressure sensor is on the side then a plug goes there. at least on mine theres a plug. dont know what yr they changed to the back of the intake but the newer ones have.
Old Jul 14, 2010 | 09:51 PM
r6rider's Avatar
its a 93 so the sensor is above the oil filter i just dont remember taking out the plug. do you think i could use something in the mean time to plug it up untill i find the right plug
