LT1/LT4 Tech 1993-1997
Possible fuel Pressure Problem
Old 12-13-2011, 01:00 PM
fperezii's Avatar
Could a bad sending unit cause fuel pressure loss, as well as the car not to start.
Old 12-13-2011, 05:50 PM
if the car is turning over and the fuel system is working correctly then no. have you tested the fuel pressure?
Old 12-13-2011, 08:58 PM
fperezii's Avatar
Yes I did a fuel pressure test and it did not have any pressure what so ever. I tested the fuel pump before I removed it. I used a power supply to apply 12 volts to the pump, but it did nothing. So I then removed it and tested it while it was out, same result. While I hade it out I tested the connection with a volt meter to ensure I was getting the 12 volts all the way to the pump, and it showed that power was present. Now all I have to do is get a new fuel pump I guess and hope that is the issue. I have read about some people using different style pumps. Is it any difference from using a OE style pump as verse a aftermarket pump like Walbro or such? Again thanks for all the help.
Old 12-13-2011, 10:19 PM
iLL95's Avatar
I Like to Party
Super Member
Sounds like it is the pump, I can't think of anything else, if the power is obviously there with no pressure,the pump evidently can't seem to pump the fuel needed. In other words,its shooting blanks.
Old 12-13-2011, 10:47 PM
fperezii's Avatar
The original problem the car had, was that it would lose fuel pressure while driving and shut off. Then 10 minutes or so the car would start back up. I am trying to help out a friend to get this thing running right again. Could the original issue be due to the opti-spark starting to go out? either way once I get the new fuel pump in I will see what the car is doing or not doing. I am not very familiar with Camaro's so I am thankful for any and all help. Thanks
Old 12-14-2011, 07:44 AM
i would say the old pump was overheating and shutting down. dont use the cheap pumps. for some reason i was thinking i have a walbro but its a granatelli 255. they may be made by the same company. seems to be working ok. i opened the plastic bucket and fit the pump in and used a plastic welder to put back together. did you use the hatch method to get the pump out
Old 12-14-2011, 09:05 AM
fperezii's Avatar
Yes I cut the area out over the unit. It makes it so much easier. All I have to do is make the hatch/cover for it. I will try to find a pump for it today and let you guys know how it went.
Old 12-14-2011, 05:20 PM
fperezii's Avatar
Well I changed the pump it it started right up. Fuel pressure is holding at around 47 psi. Now I will try to duplicate the original issue. I'm hoping that it was the pump all along.
Old 12-19-2011, 02:47 PM
fperezii's Avatar
Ok I got the car running again, but u noticed that in the morning it does not crank right up. After I drive it, stop, and park it cranks up fine. Any input on this would be great.
  #20
Old 12-19-2011, 09:04 PM
greenmachine96's Avatar
Probably due to fuel pressure bleeding off in the system. I would think that it is normal.
Quick Reply: Possible fuel Pressure Problem
