Possible fuel Pressure Problem
I have a 94 LT1 Camaro and after driving for a short while, the car will die out. It takes about 10 minutes or so, then the car will start again. Any help would be great, I do not know much about Camaro's. Let me know what you guy's think, or send me a message. New to the fourm, thanks in advance.
That does sound like a fuel pump/ injector pressure issue, it may be a failing fuel pump. Does it crank up fine? Any codes? You may need to hook up a fuel pressure gauge to gauge test valve. Are there any other problems like the car randomly shaking? A high Idle?
first need to find out if its a fuel problem or a spark problem. when it wont start do a fuel pressure test or check for spark. could be fuel pump, ignition modual and a few other things.
The fuel pump has been changed out twice. Iam going to try and mess around with the car today. I will let you guys know. Thanks for the help.
So today I messed with the car for a little while, it was kind cold out side so I didn't spend a lot of time on it. The car did not want to start at all. I sprayed small amount of starter fluid to see if it would try to start and it did, but then shut off right away. I was looking for the fuel pump relay but was un able to find it. Being that the fuel pump has been changed out, I figured I would check the relay next. Any info would be a great help, Thanks!!!
next you need to do a fuel pressure test. number 33 on the list here 4th Gen LT1 F-Body Tech Aids
Originally Posted by craby
(Post 591429)
do it only happen on cold days?
Sorry for the delayed response guys. It has been cold and rainy, so I have not had a chance to mess with the car. I finally got a fuel pressure kit, but unsure of what adapter to use. If any one could help that would be great. Thanks.
it would be the one that fits on your schrader valve.
