LT1/LT4 Tech 1993-1997
plug wire help!!!b
Old Mar 17, 2011 | 12:06 PM
jpkz94's Avatar
Default plug wire help!!!b
hey guys i need help i keep buring plug wires even tho they arent hitting my long tube pacesetters! i usaed the jegs kits for wires any help on a good set of wires better for the heat would be great!
Old Mar 17, 2011 | 12:50 PM
impalassv8's Avatar
8.5 mm or you can ask a local if there are any high heat wires. Your best bet will likely be a set of high heat sleeves. Summit has a great variety.
Old Mar 17, 2011 | 05:33 PM
torque_is_good's Avatar
I don't get it at all
I have Pacesetter long tubes and am using the yellow Jegs 8.5mm wires for 2 years. Not a lick of problems
I have them running through the stock wire channels and they fit just fine.
Old Mar 17, 2011 | 06:41 PM
jpkz94's Avatar
hey i got the jegs opti and wire kit but it came with the 8mm red plugs i think im going to order the yellow JEGS 8.5mm Ultra Pow'r Wires
Old Mar 17, 2011 | 07:16 PM
you'll get a Jegs baseball cap with your order. Be sure to get real excited.
I'm doing this from memory without looking
The wires come from the opti. #1 and #2 go right to the plugs.
the rest then run through the metal channel along the block. The 8.5's fit just fine. I bent the channel out just a wee bit but the boots aren't even close to the header (so to speak) nor are the wires
Old Mar 17, 2011 | 08:50 PM
jpkz94's Avatar
have you guys ever seen i belive its thunderracing.com they have a wire kid that runs on top of the valve covers or on the side of the covers any info on those?
thebandit110
Apr 7, 2012 07:48 PM
jackss00
Aug 6, 2011 08:10 PM
Mr_Exacto
Mar 1, 2010 12:30 PM
domo556
Oct 13, 2008 06:34 PM
adirtypoostick
82-92 V8 Tech
Apr 19, 2008 10:33 AM
