plug wire vs. header
Old Apr 7, 2012 | 04:34 PM
thebandit110's Avatar
Default plug wire vs. header
So i went to fit my new headers on while the engine was on the stand. Everything looked fine except cylinder #6. The plug wire boot was hard core touching the header pipe. I have MSD wires on the thing and I know they are good for heat. But direct contact??? should I call Flowtech? or MSD??? Or are there low profile boots on a wire kit??? All other cylinders had sufficient clearance. Anyone else have a similar issue???
Old Apr 7, 2012 | 07:48 PM
They will say buy a shorter plug. Like the Accel header plugs. You can pull the header and smack it with a ballpeen hammer for clearance. Or Hedman's are known as the best fit out there. Mine fit great with angle plugs and 1/2" dropped body mounts.
jackss00
Aug 6, 2011 08:10 PM
jpkz94
Mar 17, 2011 08:50 PM
Mr_Exacto
Mar 1, 2010 12:30 PM
domo556
Oct 13, 2008 06:34 PM
adirtypoostick
82-92 V8 Tech
Apr 19, 2008 10:33 AM
