LT1/LT4 Tech 1993-1997
Please Help!! Steering column problems
Old Dec 12, 2005 | 10:46 PM
adtsguy's Avatar
Default Please Help!! Steering column problems
My steering whell is floppy i.e. you can move it up and down about three inches. This is gradually getting worse so bad that the car will cut off if you push on it the wrong way while running. I have the steering whell off and everything pulled out of the column as far as I can go and I still cannot figure out how to tighten the steering column. Please help!!!
Old Dec 12, 2005 | 10:57 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: Please Help!! Steering column problems
what year is it?
Old Dec 12, 2005 | 11:00 PM
adtsguy's Avatar
Sorry - 1994 Z28
Old Dec 13, 2005 | 05:10 PM
RatedZ's Avatar
ORIGINAL: adtsguy
Sorry - 1994 Z28
I have a '94 as well, and while I can't say that the steering wheel is "floppy," if I pull down on it, even though it's set on the lowest position, it will still move a bit. Is this what you're experiencing, or is it really literally "flopping" around?
Old Dec 13, 2005 | 05:11 PM
There are 3 bolts attachingthe steering column flange to the firewall, and 2 bolts attaching the steering column cover to a bracket attached to the dashboard. You need to remove the lower dash covers.
bowtieguy92
Aug 19, 2010 07:19 PM
Arizona Camaro
Oct 26, 2007 04:13 PM
qaz123
Apr 28, 2007 09:59 PM
Bowlergt
Jan 21, 2007 09:54 PM
rwing7486
Jun 27, 2006 01:38 PM
