LT1/LT4 Tech 1993-1997
pistons?
Old Mar 1, 2009 | 04:18 PM
Deviousz28's Avatar
Default pistons?
I have a 94 z28 and i was wonderin if flat top hypereueteic pistons will fix the same as stock pistons.
Old Mar 1, 2009 | 07:41 PM
Saint_Ali's Avatar
you will have to get a smaller than stock size if you go with those.They have more silicon in them than the stock alluminum ones, which means they will expand more when they heat up.If you get them,they must have a loose fit when the engine is cold.I would go with a forged piston,they are less expensive and are a great upgrade from stock
Old Mar 2, 2009 | 09:06 AM
whammer3024's Avatar
ROTM Winner
why are you looking at pistons? if you give us more information then we can help you better to pick a piston. forged is probably the best way to go as ali said, mainly because it will be able to handle some nitrous later down the road
Old Mar 2, 2009 | 09:31 AM
LT1RUNNER's Avatar
Why are you chnaging to flat top pistons? Looking for higher compression and power?? Need a little more info OP.
84-z28-305
Oct 15, 2012 10:46 AM
78 on my plate
Apr 5, 2012 09:52 AM
NorthernCrew454
Apr 28, 2011 08:24 AM
mapes7
82-92 V8 Tech
Dec 10, 2010 04:36 AM
nascar88
Feb 8, 2010 06:57 PM
