LT1/LT4 Tech 1993-1997
Opti-spark Issues???
Old Jul 14, 2010 | 09:39 PM
jpmason2's Avatar
Default Opti-spark Issues???
I have a 94 Z28 Convt. A while ago the car just died on me. Took it into the mechanic and he replaced the opti with an O-reilly brand twice. The car still wouldn't run smooth. So the mechanic swapped computers thinking that was the issue. Bingo car ran great...until you shut it back off. Then it wouldn't start back up. It was now throwing a High Resolution code??....We ended up putting a Delco GM opti in it and now it will not run at all.....It will however run with the o-reilly opti until its shut off and restarted....Any Suggestions????
Old Jul 15, 2010 | 08:22 PM
are you getting power to the coil when it doesnt start? pink wire.
Old Jul 15, 2010 | 10:37 PM
Default engine cranks but will not run
see if any of this helps.
Size:  61.2 KBName:  P7150004.jpg
Size:  64.5 KBName:  P7150006.jpg
Old Jul 17, 2010 | 09:44 PM
CNCman's Avatar
Also could be the wire harness to the opti or the ECM, check craby above.
hyozanryu
Jun 15, 2013 06:43 PM
BMCossey97Z28
May 17, 2010 09:31 PM
wicked94z28
Mar 12, 2010 02:03 PM
ufnwish
Oct 8, 2006 06:38 PM
kwest
Jun 13, 2006 09:03 PM
