LT1/LT4 Tech 1993-1997
Oil pressure switch?
Old May 17, 2009 | 06:25 PM
95camarosummer's Avatar
Default Oil pressure switch?
So me and my friend have a 1995 Camaro with a 1996 LT1 in it, the problem is the oil pressure switch based on whats its doing. Our problem is we haven't been able to locate it so if you know where the switch is on the 96 LT1 that would be helpful.
Old May 17, 2009 | 10:11 PM
on a 93 lt1 its down by the oil filter.
Old May 18, 2009 | 12:21 PM
QC97Z's Avatar
The oil pressure switch is on the rear of the engine at the top near the egr hook-up. I replaced mine (on my 97) recently. I used an oil pressure sensor socket with a swivel and a couple of 10" extensions, and also had to lay on the motor to get it done. It's quite a reach for a short guy. It is angled toward the driver's side.
Old May 20, 2009 | 11:17 AM
rondavis's Avatar
the sending unit is on the top of the motor and the swith is on in the oil pan by the oil filter
Old May 20, 2009 | 12:04 PM
grimsleet's Avatar
what will be some signs of a bad oil pressure switch?
Old May 20, 2009 | 12:25 PM
rondavis's Avatar
low oil light is on all the time even with full oil
Old May 22, 2009 | 12:10 PM
QC97Z's Avatar
Ron, incorrect. A bad oil LEVEL switch/sensor will either (1) NOT trip the low oil light on the dash when the oil is actually low, or (2) always trip the low oil light even though the oil level is fine.
A bad oil PRESSURE switch is bad when either (1) no pressure reading on the dash at all, or (2) pressure gage jumps all over the place.
jdrpco
Jan 2, 2014 02:11 PM
wayne242
Oct 27, 2012 06:23 PM
BasicConcepts
Dec 9, 2011 11:31 PM
greg w
Dec 22, 2009 03:48 AM
sewerrat
Oct 19, 2006 10:46 PM
