Oil pressure switch
Old Oct 17, 2012 | 07:09 PM
wayne242's Avatar
Default Oil pressure switch
The car is a 95 Z28 LT1.
How many wires should the plug have that connects to the oil pressure switch?
Also if you unplug the oil pressure switch and your oil still max's out when you start there care, is this a wire problem?
I ask about the wires because my plug only as 1 wire and does not seem right to me. The engine is the second engine for the car (odd for a car with only 130k, but hey i got a new engine haha). So not sure if maybe they damaged the wires to the oil pressure switch.
Thanks for any tips or suggestions, trying to trace down this bug in the system.
Old Oct 17, 2012 | 07:14 PM
BasicConcepts's Avatar
Technical User
My 94 Z only had one wire.
Old Oct 17, 2012 | 08:51 PM
2Z's's Avatar
Should be a single wire. I believe its tan. Try this test. Remove the gauge cluster. Find the tan wire that goes to the sender. Cut it. Now run a wire from the sender end to the wire you cut that goes into the cluster. Turn the engine on and see if it works. youll know pretty much as soon as you put the key in the on position because it wont bury or peg.
Old Oct 17, 2012 | 08:57 PM
wayne242's Avatar
Thanks for the suggestion, i was thinking something along those lines. I noticed when i pulled on the wire to the sender, and turn the key on and then off the gauge would drop down until started(then peg out again). After starting it, it then go's back to staying pegged to max.
I'll get on this in the morning if i have some wire left in the garage.
Old Oct 17, 2012 | 09:12 PM
MKCoconuts's Avatar
Usually when it's pegged to max, it's the sensor itself or the wire at the sensor.
Old Oct 17, 2012 | 11:05 PM
wayne242's Avatar
Yeah.
What i find odd( correct me if im wrong), but with the wire unplugged the gauge should not stay pegged to max? This is what leads me to think the wire is damaged possibly.
Old Oct 18, 2012 | 12:21 AM
2Z's's Avatar
Originally Posted by wayne242
Yeah.
Mine was but I couldnt find where, so I just ran a new one to the cluster like I described.
Old Oct 18, 2012 | 04:19 PM
wayne242's Avatar
Is it possible to locate that wire under the dash without removing the cluster?
Old Oct 18, 2012 | 04:33 PM
MKCoconuts's Avatar
With the wire unplugged, it should stay pegged. Any time there's a problem where the gauge doesn't receive a signal (bad sensor, broken sensor, burned wire, etc), it pegs to max.
I'm sure you could run the wire under the dash, but it's a much cleaner install doing it the stock way. Yeah, it takes a while, but it'll help any future owners later in the cars life. I would check out the wire first and if it checks good, I would replace the sensor as they aren't more than $20 at a parts store.
Old Oct 18, 2012 | 06:51 PM
wayne242's Avatar
Yeah, think I'll replace the sensor Monday since I don't work. If that don't fix it, I'll do the wire thing. I just did not have enough time today to pull the cluster out.
