LT1/LT4 Tech 1993-1997
oil pressure problems
Old Oct 22, 2011 | 04:00 PM
Polar Bear's Avatar
Default oil pressure problems
my oil pressure is always low but when i press on the gas it goes up right away could it be my oil pump or the sensor ?
Old Oct 22, 2011 | 05:19 PM
numskull223's Avatar
How low? At what Idle?
Ive always heard, the oil pressure should raise with the rpms. Mine Idles at 700 and holds about 45pds and revd its maxs out at 80, but its not a stock pump.
i have ran 5-7 pounds at idle and it would rise when I revd, but thats an older SBC 400.
Old Oct 22, 2011 | 08:07 PM
Polar Bear's Avatar
ive never seen it go past half even when its warmed up when i first start it up it doesnt move untill i press on the gas and when its fully warmed up it is usually jus barley above the red line
Old Oct 22, 2011 | 08:58 PM
Thats bad, if it doesnt move off the redline till you press the gas. I would change the oil/filter and see if that helps . Man if it didnt i wouldnt drive it till i found the prob.
When Its cold, pressure should be higher than warm. Cold start on mine is around 70-80pound,
Old Oct 22, 2011 | 11:57 PM
Could be the oil pressure sender, or bad gage. Verify the pressure using a test gage.
Old Oct 27, 2011 | 11:00 AM
CamaroPrime's Avatar
Is it car sounds different then usual? You can also check safety fuses or does the sensor is pluged in (sometimes plug get loose).
Old Oct 27, 2011 | 01:05 PM
do what pete says, make sure your gauge is working at least close to correct, these gauges are known to be off a tad. are you hearding lifter rattle? what wt of oil are you using?
royco95
Aug 2, 2015 10:25 AM
BoricuaHec01
LS Series Tech
Mar 17, 2011 05:56 PM
tsdecker90
Oct 10, 2009 07:56 PM
86IROCZ305
Apr 10, 2008 10:33 PM
gr8cars1
May 28, 2007 10:58 PM
