LT1/LT4 Tech 1993-1997
Oil Leak behind Opti
Old Apr 23, 2012 | 03:55 PM
JeffGilbert's Avatar
Originally Posted by torque_is_good
...CUT the new gasket, put it on with a bunch of rtv where the incision was made...
What could possibly go wrong !? :-)
But seriously, the thought had occurred to me.
Old Apr 23, 2012 | 04:09 PM
You can use RTV in place of an actual gasket if you wanted to. But laying down a good bead in that cramped position would be a bit more difficult. There's nothing wrong with how t.i.g. did it.
Old Apr 23, 2012 | 07:09 PM
you can replace the pan gasket without dropping the k frame. gotta undo front motor mounts, lift the front of the motor as high as you can and then turn the crank so theres room to get er out. yep gotta take the starter out, easier if oil cooler and filter are out, oil dip stick tube needs to come out, flywheel cover need to come off. the pan gasket is re useable if it hasnt hardened from heat and the bad part to seal is the corners where the front cover, the pan and the block all come together.
Old Apr 24, 2012 | 08:08 AM
torque_is_good's Avatar
"RTV"..."surgeon like precision"....man, what kind of a doctor are you used to seeing? lmao
this is my Dr
KISS - Calling Dr. Love - Brooklyn Bridge - Reunion Tour / MTV Awards - YouTube
Old Apr 24, 2012 | 08:14 AM
lol....considering Gene Simmons' wife must be pumped up with a lot of silicone, I guess that's a fitting comparison!
Old Apr 24, 2012 | 09:19 AM
Wow, Thanks Guys.
This is the kind of been-there, done-that knowledge that ya cant get from RTFM. :-D
Now with 50% more humor at no extra charge!
Cheers
Jeff
Old Apr 25, 2012 | 07:04 PM
JGuy07's Avatar
I slid my felpro gasket on the pan without raising the engine or moving anything....slowly though. Still no leaks from the pan gasket. But my wp seal got janked up...my marker tool SUCKED apparently.
Jelz28
Jul 18, 2012 06:01 PM
Z28Freak
Apr 24, 2011 02:02 PM
94zguy
Dec 23, 2010 02:42 PM
sbcman25
Jan 29, 2010 02:01 PM
rofelz
Jun 13, 2007 06:34 PM
