LT1/LT4 Tech 1993-1997
oil leak
Old 09-09-2011 | 06:52 AM
Psycho's Avatar
I doubt that you could suck the oil out. I imagine the oil is scattered all throughout the inside of the opti. Take the opti apart and use electronic cleaner to clean the opti and shutter wheel. I know I have read where the sensor itself rarely goes out, and several members have spares from teardowns.
Old 09-10-2011 | 04:46 AM
skinut's Avatar
Thanks that's the plan at this point. Im gonna get it good and clean. It wasnt that bad but it still got in there. Fun parts gonna be changing the oil pan etc.....
Old 09-10-2011 | 10:48 AM
torque_is_good's Avatar
why are you changing the oil pan? If you mean the oil pan gasket then ok I understand because with the timing cover off you are going to end up ripping the gasket anyway (unless you are one lucky guy)
Can you borrow or rent an engine hoist? Its so much easier when the engine is lifted some. You can change the oil pan gasket with the pan still on.
Old 09-10-2011 | 11:26 PM
ok lol, ill ask, how can you change the pan gasket with the pan still on??? you need to drop the front of the pan to get the front cover off. dont have to lift the motor to do that. you have to lift the front of the motor as high as you can to get the pan off.
Old 09-11-2011 | 06:10 PM
asked and now answered
lift engine as much as you can with mounting bolts out
drop pan, remove old gasket
cut one side of new pan gasket
put gasket onto pan
rtv where you made the slice
put pan back on
so far, 1 year and no leaks for me
piece o cake
Old 09-12-2011 | 01:39 PM
skinut's Avatar
Looks like some pretty good info in the link... I own a engine hoist btw
Jelz28
07-18-2012 06:01 PM
95mero
01-05-2009 09:14 AM
derrickdiggler
10-12-2007 01:22 AM
derrickdiggler
09-27-2007 02:26 PM
daltons 1980
09-24-2007 09:04 AM
Quick Reply: oil leak
