oil leak
they make a dye that you put in your oil that will help find the leak. my guess would be the pan seal. you may want to replace the opti i know water is bad for them so i'm guessing oil is no better.
yep i had it coming from both front and back of the intake and the trany was leaking. tightened up the trany pan bolts, new intake gasket, new oil pan gasket (pita) and front cover seals and im not leaking a drop. i dont think i was losing oil from the front cover but thats were i thought it was coming from. so when i took it off i messed up the pan gasket so had to replace it.
