LT1/LT4 Tech 1993-1997
off road pipe
Old Feb 18, 2008 | 05:12 PM
93Z28joel's Avatar
Default off road pipe
Will puting a off road y pipe on my 93 z28 going tho throw a code? will it mess with my computer?
Old Feb 18, 2008 | 07:07 PM
95slvrZ28's Avatar
Default RE: off road pipe
Nope, all you're going to have to worry about is is you have to get emissions tested you're not going to pass. Your car is OBDI, so it doesn't check cat performance, that happened in 1996 when everything went OBDII.
Old Feb 20, 2008 | 05:06 PM
93Z28joel's Avatar
ok cool thanks i dont have to worry about getting tested where i live they dont test. i dont live in california so that is a +++++. thanks for your help.
Old Feb 20, 2008 | 05:21 PM
95slvrZ28's Avatar
Just out of curiosity are you running long tube headers? Just a mandrel bent Y pipe will get you some HP over stock, but if you're going to do a Y pipe you should get long tubes and a Y pipe to match so you don't replace the same part twice. Just my $0.02
Old Feb 20, 2008 | 06:58 PM
93Z28joel's Avatar
i have a set of jba hedders but they are shorties they fit the 69 camaro and alot of newer stuff i was going to see if a muffler shop can make a custom y pipe.
http://store.summitracing.com/partde...JBA%2D1830%2D5
this is what i got do you know if it will work
Old Feb 20, 2008 | 07:17 PM
93Z28joel's Avatar
I am not shere if those are the exact ones but they are close. i cant rember the part #
Old Feb 20, 2008 | 07:41 PM
95slvrZ28's Avatar
Ooh, they're going to bolt up to the heads, but I would be surprised if they actually fit into the engine bay, it's a tight squeeze for anything in there, especially if it wasn't made specifically for our engine bay. Good luck though!
Old Feb 20, 2008 | 08:59 PM
93Z28joel's Avatar
ok thanks i am going to bring it to a muffler shop and ask them i am not going to try and do it myself. if they dont work i am going to sell them and buy the bbk hedders and y pipe and put a test pipe where the cat goes. thanks for you help.
supafly147258
Aug 31, 2011 12:16 AM
94junker
Jun 15, 2010 11:36 PM
savage02
Jun 9, 2010 09:46 AM
ssoper89
Dec 8, 2009 12:27 AM
tman21786
Mar 16, 2008 02:24 PM
