LT1/LT4 Tech 1993-1997
odd knocks at 3500 rpms
Old Feb 9, 2006 | 09:55 AM
midngtcstm's Avatar
Default odd knocks at 3500 rpms
i was wondering if someone could coud help me out? i have a 94 LT1 with a V6, when i get to about 3500-4000 rpms to shift it starts knocking really bad. thought if might be plugs and wires changed them and still does it. any one got anything
Old Feb 9, 2006 | 02:01 PM
creep's Avatar
Default RE: odd knocks at 3500 rpms
um, aren't lt1's v8?
Old Feb 9, 2006 | 06:24 PM
wishmaster's Avatar
It's it knocking or ticking? If it's knocking it could be a couple of things, rod bearing or wrist pin. If it's ticking it could be several things-cheap gas,cam,lifters,valves,optispark. Hope this helps,when you get it fixed let use know what was wrong.
Old Feb 9, 2006 | 07:16 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Yes LT-1 is a V8.....maybe he made a typo
Old Feb 10, 2006 | 05:36 PM
It sounds like spark knock (ping) as it seems to be affected by load. The thing is to find out why. Is the SES lite on? Make sure the knock sensor is good an screwed on tight, make sure the knock sensor module is good. Also, has someone messed with the computer? You should be using premium fuel, this engine was designrd for it.
Old Feb 14, 2006 | 02:55 PM
midngtcstm's Avatar
no its definatly a loud obnoctious knocking im bout to say forget it and take it to the dealership that i bought it from and say fix it and its going to be free
Old Feb 15, 2006 | 09:56 PM
In that case, take it back to the dealer and get them to fix it while the warranty is still good.
Old Feb 19, 2006 | 08:52 PM
94Z28SHAKER's Avatar
tell them to check the whole car and fix everything, probably need intake manifold gasket by now anyway.
im guessing its a lifter or bearing.
Old Feb 22, 2006 | 12:47 AM
midngtcstm's Avatar
i took it back and they are going to replace the entire engine while im out on deployment so im good to go now thanks for that
AmirGTR
Jul 17, 2010 08:57 AM
laywezzie
Apr 21, 2010 05:50 AM
skylinrcr01
Aug 21, 2008 10:30 PM
82v8z28
82-92 V8 Tech
Apr 1, 2007 12:08 AM
concierge11
LS Series Tech
Sep 1, 2005 12:42 PM
