LT1/LT4 Tech 1993-1997
obd1 or obd 2
Old Nov 12, 2006 | 01:09 AM
kennyshouse's Avatar
Default obd1 or obd 2
i have a 93 firebird and it has the 12 pin connecter my ? is is it obd1 or 2 the book says on obd1 theres two wires beside each other on the right you can jump for codes and two up and down far left well my connecter has 3 on the right 2 top one bottom and one on the bottom left i know its supposed to say under the hood but i dont see it anywhere
Old Nov 12, 2006 | 03:16 AM
95slvrZ28's Avatar
Default RE: obd1 or obd 2
OBDII kicked in on the '96 models, so yours should be OBDI, unless some rediculous and pointless modding went on...
Old Nov 12, 2006 | 03:27 AM
thats cool ....can ya tell me why my wires in my test port dont match the diagram in the book? they are in diferent slots i was tryin to jump the test slot with the ground to get the codes but all that happens is my fans turn on when i jump the ones that the book says
Old Nov 12, 2006 | 11:03 AM
Some of the cars came with OBD2 ALDL connectors, but are still OBD1. This can cause all sorts of confusion, especially when trying to pull codes without a scanner.
Old Nov 12, 2006 | 10:56 PM
AlfredB18's Avatar
I believe with the LT1 era F-bods, only the 93 LT1 can be jumped with a paperclip (or other tool of choice) to have the codes read.
Old Nov 12, 2006 | 10:58 PM
yes well thats what i have is a 93 with the lt1 motor
Old Nov 13, 2006 | 01:27 PM
The 93s are definetely OBD1, and the connector has the OBD1 pin pattern. The ALDL connector is inside the car under the dash, near the steering column.
OBD1 Connector pinout, looking at front of ALDL connector:
F E D C B A
G H J K L M
A ground
B diagnostic request
C-F not used
G keyless entry
H-L not used
M serial data
OBD2 Connector pinout:
1 . 2 . 3 . 4 . 5 . 6 . 7 . 8
16 15 14 13 12 11 10 9
1 not used
2 serial data
3 not used
4 ground
5 ground
6-15 not used
16 battery voltage
Old Nov 29, 2006 | 11:46 PM
Camaron32's Avatar
I have a 1995 Camaro 3.4L and I've been wondering if it is OBDI or OBDII. So the easiest way to tell is the number of pins? Or is there another way to find out.
Old Nov 30, 2006 | 01:24 AM
95slvrZ28's Avatar
Your '95 is probably like mine, it's OBDI, but has the OBD2 connector. I tried to get the codes read once, but it didn't work...
Foresemo29
Nov 21, 2013 08:15 AM
wayne242
Oct 16, 2012 07:45 PM
jkeaton
Jun 12, 2012 08:16 AM
thetal1
Feb 16, 2010 12:14 PM
contryboy
Sep 14, 2009 11:34 PM
