obd1 question
Old Oct 16, 2012 | 07:01 PM
wayne242's Avatar
Default obd1 question
Anyone know if those obd1/obd2 cards will work on a 95 z28? Like one end as the obd1 plug and the other end as the obd2 plug.
If not can anyone point me in the direction of a obd1 reader(or a laptop hook up if possible for these cars).
Thanks
Old Oct 16, 2012 | 07:05 PM
BasicConcepts's Avatar
Technical User
Get an aldl cable than you can hook it up to a laptop and scan like that.
Old Oct 16, 2012 | 07:11 PM
wayne242's Avatar
Thanks, found OBD Diagnostics, Inc. - ALDL (GM OBD1) Cable with 12 pin Connector . Seems a bit pricey, but if it works that's all that matters.
Old Oct 16, 2012 | 07:15 PM
Technical User
You could always get an obd1/obdII scanner, it'll be more than 60$ but you can use it on every car.
Old Oct 16, 2012 | 07:41 PM
wayne242's Avatar
I have 2 obd2 scanners and laptop hookups. Just needed a obd1 for my camaro, so probably ordering the one you suggested tonight if i don't run across it cheaper on ebay( I know I'm tight with money haha).
Thanks
Old Oct 16, 2012 | 07:45 PM
Technical User
Check amazon and newegg there usually the cheapest
Foresemo29
Nov 21, 2013 08:15 AM
JaredSmith
Jul 6, 2013 03:54 AM
craby
Apr 8, 2010 11:42 AM
contryboy
Sep 14, 2009 11:34 PM
kennyshouse
Nov 30, 2006 01:24 AM
