LT1/LT4 Tech 1993-1997
No heat!!
Old Nov 26, 2006 | 04:36 AM
cwill8494's Avatar
Default No heat!!
i have a 94 lt1 camaro and the car is at normal operating temp., but still no heat. ive replaced the t-stat, i did a heater core, and i flushed the whole system twice. all the cables and junk on the inside are in perfect working order, and the best heat i can get is only luke warm. am i missing something here? thanks for any help!
Chris
Old Nov 26, 2006 | 11:04 AM
Default RE: No heat!!
During your flushing, did you pressure flush the heater core? Check the hoses going to the heater, they both should be at the same temp as the radiator hoses. If they are running cool, the heater core is clogged.
Old Nov 26, 2006 | 03:46 PM
cwill8494's Avatar
i did the flushing after i had the new core in. the heat was working alright, and then it just stopped. how would i go about unclogging my new heater core?
Old Nov 29, 2006 | 01:59 AM
Diconnect both heter hoses from front of engine, stick the end of a garden hose with a nozzle into one of the hoses and force water through it till it comes out the other hose.
c4maro
Feb 10, 2011 08:21 PM
92RS FTW
82-92 V8 Tech
14
Nov 26, 2010 07:37 AM
burning camaro
Nov 9, 2010 06:15 PM
sl1foru
Nov 10, 2007 10:16 AM
FullThrottleChick
Dec 6, 2005 09:59 AM
