newbles exhaust question here
So I've got a Borla CatBack with the 3/4 open restrictor plate on it right now, and decided the other day that I wanna replace it with the full open plate. Well, I started removing the 3 bolts that hold it together, and one of the bolt heads snapped clean off. Any easy way to remove the rest of the bolt that's stuck inside?
Like I said, newb question, I just don't really have the time to tinker around with trial and error lol.
Go to Sears and get ya an ez out set (you'll probably wanna make sure it has a T-handle,or get one separately). Drill through the center with the appropriate size drill bit, hammer in appropriate ez out, twist out.
http://www.sears.com/shc/s/p_10153_1...crew+extractor
This set works pretty good, but like said, a T-handle would be very beneficial, if you don't get one you'll have to hold it with vise-grips.
My comments come from my experience as an aircraft mechanic and may (probably not) differ from what you are needing.
