LT1/LT4 Tech 1993-1997
Need to rebuild want new mods
Old Dec 12, 2006 | 06:22 PM
97SS30th's Avatar
Default Need to rebuild want new mods
Hey I just bought a 1997 SS 30th anniversary. It was overheated before I got it and now I need to do a rebuild but I want to make it into a street/strip car. I would just like to know of some good mods for this engine while I rebuild it. And also the gas gauge doesn't work its stuck right under the half tank mark. Any ideas would be appreciated thanks.
Old Dec 12, 2006 | 06:48 PM
shnormo's Avatar
Default RE: Need to rebuild want new mods
Gas gauge will be cuz of a stuck float in the fuel tank or a bad circuit some where.
Old Dec 12, 2006 | 11:32 PM
97SS30th's Avatar
Thanks I had heard that it might be a bad ground on top of the gas tank what do you think the probability is of that.
Old Dec 13, 2006 | 05:29 PM
carguylt1's Avatar
Mods for your engine are like any other cam head work and boreing it out you may want a bigger throttle body and injectors if your planing some thing major.
Old Dec 14, 2006 | 08:59 PM
97SS30th's Avatar
I was actually wondering what type of cam because i'm not sure what type to put in.
Old Dec 15, 2006 | 01:31 PM
Check with one of the cam companies, tell them what you have & what you want to accomplish. The will recommend what is most suitable.
Old Dec 15, 2006 | 06:26 PM
As for the engine rebuild, you could go ahead and build a stroker for about the cost of a 350 rebuild, but if you go the sroker route, you should aldo upgrade the heads, cam, and exhaust.
Destoryer
Sep 19, 2010 01:58 PM
SloBalt
General Racing/Tech
Dec 5, 2009 07:48 PM
thetal1
Sep 9, 2009 02:16 PM
1Slo_Camaro
Nov 26, 2007 11:25 AM
KoRN_Munky
Jan 22, 2007 08:01 PM
