LT1/LT4 Tech 1993-1997
Need Help QUICK pleeassee
Old May 17, 2007 | 04:48 PM
user 7208220's Avatar
Banned
Default Need Help QUICK pleeassee
asdfa
Old May 17, 2007 | 05:23 PM
94Z28SHAKER's Avatar
Default RE: Need Help QUICK pleeassee
are you sure your fans are working? you should hear them turn on when it gets near the red zone.
did you bleed the coolant system properly? sometimes air bubbles get trapped in the cooling system and makes them overheat, if not bled correctly.
check your front bumper cover, make sure its tucked under the nose and bolted correcly so nothings hanging in front of the Air dam under the car, ive seenthem just hanging, and they willblock air flow to the radiator.
last but not least make sure your coolant is nice and bright green, if you need a flush, spend the 15 bucks and change it properly.
CountTripula
Mar 14, 2014 08:01 AM
danstheman454
Apr 17, 2011 08:17 PM
LT1FTW
Apr 20, 2009 12:40 AM
whiteandblack93
Jul 7, 2008 12:59 AM
stephensilence
Mar 21, 2008 07:51 PM
