over heating problems
Old Mar 12, 2014 | 10:20 AM
CountTripula's Avatar
Default over heating problems
So I took my car to the shop and now its over heating. Had the rocker arms adjusted when we put it in the shop. It literally takes no time for it to jump up near 260. I have to frequently stop and turn off the car. Any suggestions?
Old Mar 12, 2014 | 10:45 AM
MKCoconuts's Avatar
Are the fans kicking on and off? Make sure you still have the air dam that sits under the car behind the bumper. People will take it off because they don't like how it looks but it's their to help scope air up into the radiator. Could be air in the system or you could be low on coolant, though that should trip a light.
Old Mar 12, 2014 | 09:01 PM
Old Mar 13, 2014 | 03:47 PM
Bought a new thermostat still doesnt help any. My heat isnt even working throws out cold air.
Old Mar 13, 2014 | 05:01 PM
ded2me's Avatar
Oh wow. So your coolant isn't circulating? My guess is a bad water pump.
Old Mar 13, 2014 | 09:58 PM
camaroteen82's Avatar
that would mean your low on coolant.
Old Mar 14, 2014 | 07:36 AM
MKCoconuts's Avatar
Check your coolant level but also lightly touch your radiator hoses while the car is warm. Check to see if they're warm/hot or cold.
Old Mar 14, 2014 | 08:01 AM
bad install of the thermostat (up side down, offset, stuck), low on coolant, plugged radiator, air lock. all i can think of. park on a steep hill with the front of the car on the up side. let cool and check coolant level in the radiator.
B_Dubya
Sep 2, 2013 01:11 PM
lightningcruiser
Nov 6, 2012 08:33 AM
mrsdeano
Sep 23, 2010 10:35 AM
SurfMunkey
Aug 23, 2010 01:07 PM
coolcat
Jun 17, 2006 07:45 PM
