LT1/LT4 Tech 1993-1997
Need help fast!
Old Oct 9, 2010 | 12:34 PM
critt86's Avatar
Default Need help fast!
My car won't start bc it keeps busting the ignition fuse. Any ideas???
Old Oct 9, 2010 | 01:07 PM
osduck5's Avatar
Time to get the mulit meter out! Have you done anything to your car lately that could cause this, such as rewiring anything? I would start by checking the wiring at the bottom of the steering column to see if anything is shorted in the column. You have a direct short to ground (if the fuse is the right amp). Check the battery cables and wiring harness for any breaks or places where the insulation may have been rubbed off, all the way down to the starter wiring to the solenoid. Although, I would think if the main battery cable was chaffed, it would pop one of the fuse liinks.
Old Oct 9, 2010 | 07:53 PM
what yr?
myles
Jul 9, 2009 12:57 AM
trexbarney7791
Jan 16, 2008 10:14 PM
91 RS
General Racing/Tech
Feb 6, 2007 04:35 AM
mwood88
Dec 1, 2006 11:34 PM
