LT1/LT4 Tech 1993-1997
My fans arent turning on
Old Jan 8, 2012 | 09:34 PM
b0banna's Avatar
Default My fans arent turning on
I have a 96 z28 its manual. Ive replaced all the main things (radiator, water pump, thermostat, fan "switch", hoses). We checked the fans by attaching them to the battery, but wont start up in my car. Today I started it and drove off right away, it was almost to red before I pulled over. My heater was blowing cold air, something clicked and started blowing hot air and my car went back down to the middle temperature. What could it be? I've heard different things, something about clutch fan?
Old Jan 9, 2012 | 08:27 AM
greenarrow's Avatar
September 2009 ROTM
I'm going to assume that you're talking about your engine cooling fans and not the fan for your HVAC. Have you checked the relay and fuse in the engine bay? Those may have bene damanged when the rest was replaced if they were not pulled or the battery was not disconnected.
Old Jan 10, 2012 | 10:43 AM
sgtdupree's Avatar
yeah it's the fuse. I was havin the same problem I went through the whole cooling system. I got wired mine to the battery and they came on. I sent it to the shop yesterday and they jus called and said it was the fuse.
Old Jan 14, 2012 | 11:15 AM
the radiator fan should not have anything to do with the heater not putting out hot air. if the heater is pushing cold air when the motor is hot it usually means your very low on coolant. first check the coolant level in the radiator. if its full then i would suspect the thermostat is sticking. heat from the heater is controled by a flap that runs the air threw the heater core for heat and does not for cold.
androzer
Aug 13, 2012 10:13 PM
Stoff777
Mar 4, 2012 01:45 PM
auto
Dec 21, 2010 11:46 PM
ZOHHH6
Aug 31, 2009 07:43 PM
jason7504
Sep 18, 2008 10:21 PM
