LT1/LT4 Tech 1993-1997
muffler removal
Old Jul 20, 2009 | 10:38 PM
red star's Avatar
Default muffler removal
I have to change my fuel pump so i went to take it off and....how the hell do you get the inlet from the muffler out?
Old Jul 20, 2009 | 10:51 PM
Saint_Ali's Avatar
i used a jigsaw
Old Jul 20, 2009 | 11:01 PM
red star's Avatar
did you just weld it?
Old Jul 20, 2009 | 11:03 PM
Saint_Ali's Avatar
you can or you can use clamps
Old Jul 20, 2009 | 11:05 PM
red star's Avatar
arg. i was trying to pull the pie out. twisting, pulling, wood and a BFH. i split the pipe a little....if id have known to just cut the damn pipe...
Old Jul 21, 2009 | 01:13 AM
The problem is the clamp puts a crimp all around the pipe and locks the two together. I take a sawzall and cut the outer pipe at an angle starting from the end. Just cut through the outer pipe, but not as far in as the inner pipe is. Then with a chisel and hammer, get under the open cut end and peel it out a little. That should loosen the grip enough to get it off.
Toxic
Apr 15, 2012 09:20 AM
dacats67
Feb 19, 2010 10:07 PM
thetal1
Jun 28, 2009 03:12 PM
supernaturalZ28
Jul 12, 2008 01:11 PM
Jims94LT1
Feb 11, 2007 12:42 PM
