LT1/LT4 Tech 1993-1997
mileage adjustment for new cluster
Old Aug 14, 2007 | 06:41 PM
tyler2497's Avatar
Default mileage adjustment for new cluster
I got a new gauge cluster for my '94 formula and I need to add some miles to the tachometer. Does anyone know how to do that?
Old Aug 15, 2007 | 10:48 AM
Chappie99's Avatar
Default RE: mileage adjustment for new cluster
First you dont add miles to a tachometer, maybe a speedometer.
Old Aug 19, 2007 | 11:41 PM
95slvrZ28's Avatar
ummm...Chappie, since when are miles a unit of speed? You add miles to your tach, you would add miles per hour to your speedo, but you really can't do that anyway. On the other hand, back on topic, I'm not exactly sure how you'd go about it, check all the connections etc. on the back by the tach, see if you can't just swap the tach from your car into the new guage cluster, that'd probably be the easiest way.
Old Aug 23, 2007 | 07:17 PM
chrshadil's Avatar
You could do it the same way crooks roll them back. I don't know how they do it though.
Old Feb 1, 2008 | 07:55 PM
importmd's Avatar
two ways go here and use that info http://www.9c1.com/technical/camaro/odometer.htm
or just swap the odometer
Sheepdog
Oct 26, 2011 11:14 AM
ENTRDRGN
Jan 28, 2011 12:04 PM
89cam
Jan 13, 2011 09:12 AM
80z28guy
70-81 V8 Tech
Feb 18, 2010 07:41 PM
hshawn31
Jan 10, 2008 10:19 PM
