LT1/LT4 Tech 1993-1997
lt4 hot cam power gains
Old Dec 29, 2011 | 08:20 PM
Old Dec 30, 2011 | 07:49 PM
BigCat2010's Avatar
Personally, I'm not a fan of the lt4 hotcam. I just don't like the rougher sound at idle...
but I think thisss is a pretty nice cam.
Edelbrock.com - Camshafts & Lifter Kits - Chevy - LS1/LT1
Just my 2 cents. Though the Lt4 hotcam is indeed a great choice...
Old Dec 30, 2011 | 10:20 PM
skinut's Avatar
That sound is a must have for me... I really like it. Thanks for the link craby, it will be useful. Didnt get to measure them tonight. Have a slight issue. The dowel pin of the used cam was tapped in flush with the cam gear. Any suggestions on how to get it back out to where i need it? I'm not having any luck...
Old Dec 30, 2011 | 10:22 PM
sure they didnt cut it off. could drill and tap it so you can get a slide hammer on it.
Old Dec 31, 2011 | 06:55 AM
skinut's Avatar
Yea im pretty sure. Thats a good idea. Ill just drop it off at the machine shop and let them deal with it.
Old Jan 2, 2012 | 09:46 PM
skinut's Avatar
The pin wouldnt budge! Not even with the slide hammer. Ended up cutting the pin off the stock cam with a band saw. Carefully welded it to the end of the hot cam. Cut it off to .620 and ground it smooth... Problem solved. Just thought id share in case anyone else ever has this problem.
jasonh3609
Nov 23, 2011 11:12 AM
illestz28
Aug 9, 2011 12:31 PM
yamahazinger
Oct 28, 2009 12:15 PM
MidnightLS1
LS Series Tech
Aug 5, 2008 06:10 PM
evolution1
Dec 10, 2006 07:36 PM
