lt4 hot cam power gains
Ok so ive got the motor out for crank repair and new set of rings... So i figure now or never. Id like to get a cam in there but im on a budget. Ive already spent a bundle on rebuild parts, gaskets, and new tires for the truck. :icon_steer: 36'' pj's youch!! Anyway ive found a hotcam kit for 300 bucks less the retainers, seriously considering do this. I know there are alot of better cams but this seems like a decent deal. Im not looking to set and land speed records. Just wanna wake it up a bit and have a choppy idle. I've read alot of posts on the cam. So hate it some love it. Just curious what kind of power gains ill see and if anyone here has had a good experience with this set up.
are you looking at just a cam or the whole valve train... youll want new lifters pushrods 1.6 roller rockers also in order to get full potential at least a nice set of lt headers a cai and a tune
300 bucks for the cam, springs, lifters, and 1.6rockers. He is also throwing in a set of light weight sodium filled valves which i know nothing about btw. Ill have to spring for some headers if i get this and a pcm for less tune unless you guys know of a better tuner to recommend. I was wondering if i can get by on stock manifolds for a couple of weeks... But ill probably just do it right the first time.
you can pop a cam in without headers or a tune and it will make a difference but you wont get full potential without them also ive heard solomon does a better job than pcmforless
although the hot cam is not that hot, that is a good deal. save a couple bills and gain some hp. solomon is lt1pcmtuning here LT1 PCM Tuning - OBDI/OBDII PCM Tuning/Programming Service
Any clue what kinda gains ill see with this setup and a set of longtubes? Solomon is who i will use then... Thanks
Originally Posted by skinut
(Post 596715)
Solomon does a great job and i won't use anyone else |
I bought the kit. It will be here tomorrow. Can i use the stock pushrods? Thats the only thing its not coming with.
nope gota measure for the new ones unless you know what length the ones that are supposed to be with the kit
Good call. Talked to my machinst today when i picked up the crank. He said the same thing. He's gonna come over tomorrow evenin to measue them up.
