LT1/LT4 Tech 1993-1997
Lt4 Hot Cam??
Old Oct 4, 2006 | 11:29 AM
Camaro_dudeZ28's Avatar
Default Lt4 Hot Cam??
I am getting my LT1 completely overhauled and I wanted to put an LT4 Hot Cam, but I am not sure if I am going the right way. What should I do??? Need advice!!!
Old Oct 4, 2006 | 05:07 PM
Default RE: Lt4 Hot Cam??
The Lt4 cam will give a good boost, but to get the full benefit you need to get the full kit, including LT4 springs, heavy duty timing chain & sprocket set, and roller rockers. GM use to list two varieties of the Hot cam, one using the standard rocker arms and one for roller rockers. For best results get the one for the LT4 roller rockers, which produce a higher lift. Also LT4 heads and intake manifold will complete the package.
Old Oct 4, 2006 | 07:28 PM
95slvrZ28's Avatar
Just some insight if you buy the "LT4 Hot Cam kit" from GM performance parts it comes with stiffer valve springs, and the 1.6 roller rockers. It's a pretty good deal.
http://store.summitracing.com/partde...5&autoview=sku
Old Oct 4, 2006 | 09:32 PM
Forgot to mention, get the PCM tuned after you change the camshaft.
Old Oct 5, 2006 | 01:41 PM
Thanks for the advice. I am going to go with the Hot Cam Kit. At Summit its only $529.95, which is not a bad deal. Thanks once again
