LT1/LT4 Tech 1993-1997
transmission bar
Old Oct 4, 2006 | 09:20 AM
Z28man's Avatar
Default transmission bar
ok i have a question about this bar that connects to the transmission and runs to the rear end. what is that black bar called. i would i know if that goes bad. i bought a hayne mauel book. it does not say anything about this bar. also where could i get one of these bars beside the dealership prices.
Old Oct 4, 2006 | 04:02 PM
GsusFrk's Avatar
Default RE: transmission bar
the Drive Shaft? is that the bar your talking about or is it another one that i don't know about.
Old Oct 4, 2006 | 04:58 PM
The bar you metioned is called a torque arm & keeps the rear axle in place. You can find stock units at salvage yards, or you can get after market heavy duty units from many sources, including Jegs & Summit. Outside of actually getting bent or broken, the only thing that usually goes bad is the rubber cushion at the transmission end of the bar.
Old Oct 5, 2006 | 07:33 AM
Z28man's Avatar
thanks for the info z28pete. i think it that rubber cushion that i need. is that a difficult job to change myself.
Old Oct 5, 2006 | 07:04 PM
Not that hard, but easier with a helper. Also change the transmission mount while you are there, because it ususally goes bad also.
Inked88
Jul 27, 2011 10:57 AM
dsinclair999
Feb 21, 2011 11:24 AM
randolphdelpriore
Jul 4, 2008 11:05 PM
DeputyDog
May 22, 2008 02:45 PM
camaro girl
Apr 8, 2007 04:58 PM
