LT1 Swap info wanted
So I have decided to drop an LT1 into my 91 rs but i didnt know where i could get a good replacement LT1. I was looking at scoggin ****ey but i couldnt tell the difference between them all. Heres the site http://www.sdpc2000.com/catalog/3832...te-Engines.htm . Would it be better to get a turn key type crate or a partial and build it myself, or even to check out a local junkyard. PS what other parts would I ned in order to successfully swap the engine ie: t56 tranny, driveshaft, rear, axle, ecm, wiring harness, ..... anyhing else? (assuming the motor comes turn key) Thanks --Kevin PS i have posted this in Third Gen forum also
RE: LT1 Swap info wanted
wow, they want a LOT for those, check out jegs, they have a large inventory of different motor's and LT1's, and they carry the other stuff you need, or e-bay, its decent if they live close,
here is a good site for ya, they have eveything you need, they could install it aswell
www.fbodymotorsports.com
