Lt1 shuts down help!!!
#21
Ok so i just got in tuch with the guy who programed my pcm this is what he said:: "I checked the file and the VATS is disabled. There is one thing that is enabled called "Data Stream Fuel Enable", which is just below the VATS. My car doesn't have it selected (but has the Y-body VATS selected, go figure) so that could be causing the problem. If you can send it back I can try taking that out... Other than that I am clueless."
Any one know about this? is their away i can disable or enabe this w/o sending it back to him or does this sound like it could be the problem?
#22
check the ohm output of your temp sensor on the water pump.
http://shbox.com/1/4th_gen_tech2.html#ect
#23
Well temp is not the problem it dont run more than 3 seconds so its not getting hot. tps map and mas are hooked up but idk how i can test that they are working. Well im going to hook up the computer today to check it out ill see if i can figure it out. would any one of thease things failing cause thease simptons?
y is corvette body, but that still won't change much ... for the vats , it's disabled ...
as for data stream fuel enable ... wish i had one i could try.
need to get some info from a dealer about the programing options.
