LT1 issues after blown head gasket repair
I can see your point. Guess I was being hasty. Just fixed the exhaust leak, may have a small one on the passenger side but its barely noticeable. Also theres a sensor in the down pipes after the collector point not before like I had said earlier.
Letting it warm up right now- now signs of smoke like earlier. Going to set the rockers once I see if my temp gauge is working.
i had set them cold just to get it running. I think they were to tight had to loosen them a bit to get them to clack. maybe I set them on the wrong #1 cylinder stroke? Its running a lot better but doesnt have that kick when I get the pedal down. Before it would break the tires loose no problem.
When i set the rockers am I trying to get rid of the clacking then a half turn or am I trying to get them to clack (louder sound) then tighten til thats gone, then get rid of a quieter clicking?
also when you say to retighten the bolts you mean the exhaust right?
losen till you get a clack, tighten till clack stops, tighten 1/4 turn, tighten 1/4 turn for a total of 1/2. you have roller lifters and they are a little noisy so i think thats what your hearing.
