LT1/LT4 Tech 1993-1997
LT1 cylinder head
Old Oct 11, 2006 | 09:28 PM
94Z28SHAKER's Avatar
Default RE: LT1 cylinder head
yup go with the LE2 if you want the big performance, or the LE1 set if its your daily driver.
Old Oct 12, 2006 | 09:21 AM
Saint_Ali's Avatar
thats a little expensive for me right now, i was think about going with edelbrock heads and possibly cam to match itEDL-61909, would this be good to and still get decent gas mileage
Old Oct 12, 2006 | 10:30 PM
uncle bill's Avatar
ALIH
Those are excellent flow numbers. The 195 cc runner isn't too big for a daily driver. You will need to port match the intake manifold. If you use those heads with a good set of headers and, say, an LT4 cam Kit, You should see HP numbers in the 400 range. Good luck.
Old Oct 13, 2006 | 09:59 AM
Saint_Ali's Avatar
if i go with the heads from trick flow, would that kill my gas mileage ?
Old Oct 13, 2006 | 11:19 AM
uncle bill's Avatar
It shouldn't, might even help a little.
Old Oct 20, 2006 | 09:02 PM
Saint_Ali's Avatar
what cam should i get to support the heads, i tried contacting comp cams but i dont know all the details with the engine bore,stroke etc. i would like to get a good cam that i could use now that wouldnt hurt my car that would help when i get the heads installed, any ideas ? summit racing has some but im not sure which one would be right
Old Oct 21, 2006 | 01:21 PM
uncle bill's Avatar
The factory cam is like 204-213 duration @ .050" so based on that a 220-230 @ 050 would be pretty safe. About 15 degrees more than stock and put it on a 112 degree lobe seperation. Both Crane and Comp have cams in that area. It shouldn't be too hard to find one. Jegs or Summit have them listed online.
pfleger
Jan 12, 2012 07:57 PM
Dwight
Jun 6, 2010 04:54 PM
slvrblt2
Jan 7, 2010 09:44 AM
HardTop
Oct 28, 2009 03:56 PM
Connerveritas
Jan 22, 2007 05:18 PM
