LT1/LT4 Tech 1993-1997
Low coolant light
Old Oct 24, 2010 | 10:24 PM
xXChipXx's Avatar
Default Low coolant light
Ever since ive had my car its showed a low coolant light constantly. Never had a problem with leaks. Even when I fill it from working on it it shows up. Where is the censor for it?
Old Oct 24, 2010 | 11:12 PM
Sensor is on the outside of the radiator, passenger side, top.
Old Oct 24, 2010 | 11:39 PM
xXChipXx's Avatar
Thanks, I realized after I asked how obvious it is.
Old Oct 25, 2010 | 06:55 AM
osduck5's Avatar
I read somewhere that the low coolant light and the sensor are a direct run to one another and has nothing to do with the computer of the vehicle. So replacing or cleaning the sensor should solve the low coolant light issue but I have read some post on the web where replacing the sensor did not solve the problem.
Old Oct 25, 2010 | 09:00 AM
Grandpaswagon's Avatar
The sensor is a simple switch. I can't remember for sure, but I think that it is normally closed when it senses coolant. If you replace the sensor, and the light stays on, check the wiring between it and the dash for a possible open or short.
Old Oct 25, 2010 | 09:26 AM
mab6680's Avatar
i just unplug them when they go bad i had a lumina that i changed the sensor 3 times in a six month period they go bad often unplugging them shuts the light off
Old Oct 25, 2010 | 01:05 PM
greenarrow's Avatar
September 2009 ROTM
They are cheap and easy to fix, check gmpartsdirect.com for the part. It's a good thing to have working properly for peace of mind.
bill2129
Jul 24, 2011 10:42 AM
evilbeef54
Jul 27, 2008 09:47 PM
stud1502
Sep 17, 2007 04:54 PM
Saint_Ali
Dec 15, 2006 08:54 PM
Z28man
Oct 6, 2006 09:41 PM
