LT1/LT4 Tech 1993-1997
Interesting Issue...
Old Jul 11, 2009 | 10:02 PM
ect. hope u can read it. its from my 93 book.
Old Jul 12, 2009 | 02:19 AM
Mr_Exacto's Avatar
So there is a code 29!!!
CODE 29 = Secondary Air Injection (open circuit in AIR system)
You said the fuses were all fine and wrote 7.5. There is one Air Pump fuse (not relay) in my 94 Camaro Z28 and it is 20 amps, located in position number 7 in the fuse box under the hood. It is not 7.5 amps, if that is what you were referring to. If you pull this fuse out, you will get a code 29, the SES light, and the fans will come on. Two other people on this forum had this fuse blow and had the SES light come on along with the fans. Code 29 can also be generated from a problem in any part of the air pump circuit. If you are certain that the air pump fuse is fine, then you can look at the connections going into your secondary air pump, along with the O2 sensor in the exhaust pipe. A severed wire on either of these parts may generated code 29.
Location of air pump: Near water pump http://shbox.com/1/temp_sensor1.jpg
Location of O2 Sensor: Near oil filter
http://shbox.com/1/ho2.jpg
CODE 32 = Exhaust gas circulation (EGR) failure - "Check the vacuum source and all vacuum lines. Check the system electrical connectors at the ECM/PCM and EGR valve. Replace the EGR valve or ECM/PCM as necessary." - 93-02' Camaro/Firebird Haynes Repair Manual
Old Jul 12, 2009 | 06:33 PM
Unit94Z28's Avatar
ITS FIXED!!!
THANK YOU THANK YOU THANK YOU to everyone who help with this and esp. Mr. Exacto!
The fuse WAS blown...sooo i replaced it and it blew it again right away soo I disconnected the AIR pump and everything is working perfectly!
Again, THANK YOU soo much
jkeaton
Aug 11, 2012 11:46 AM
gfrench
Mar 28, 2011 08:05 PM
Mustang_Eater
Dec 2, 2010 12:30 PM
