LT1/LT4 Tech 1993-1997
valve cover removal
Old Jul 11, 2009 | 05:33 PM
black95z28's Avatar
Default valve cover removal
okay so this will be my first time removing a valve cover. i just want to pull the drivers side one off. in my chilton book, it says pull the PVC hose from the cover. then remove the air injection fitting from each exhaust manifold (is this on the drivers and passenger side?) and remove the bolts. now the reason i am doing this is so i can possibly get a casting number to see if i have AFR heads or not. now when i go to put it back in, is a new gasket required?
Old Jul 12, 2009 | 05:31 PM
95slvrZ28's Avatar
Required, no. A good idea, probably. If you remove something that uses a gasket, providing you don't destroy the gasket, sometimes you can get them to reseal correctly. If you can't you're going to have a brand new oil leak. I would put a new gasket on if I pulled my valve covers...
Old Jul 12, 2009 | 06:54 PM
blackz87's Avatar
Not a good idea pulling the valve cover unless you really have to. Why are you curious about the heads??? If it is not broken, leave it alone is my opinion.
Old Jul 12, 2009 | 07:00 PM
black95z28's Avatar
well im trying to figure out if it has aftermarket AFR heads or not. and idk how else to find out
mezzyshredder
Jun 4, 2012 07:49 AM
keaboi
May 29, 2011 03:29 AM
aka_australia85
Jan 31, 2011 07:30 PM
Mustang_Eater
Nov 27, 2010 07:48 AM
mstephens20
Mar 26, 2008 09:23 AM
