LT1/LT4 Tech 1993-1997
Intake Manifold
Old 12-19-2008, 07:47 PM
Default RE: Intake Manifold
95slvr brings up an interesting point. As you go to lower gears using the same type rear end, the pinion gear has to be made smaller in order to get the additional multiplication (no room to make the ring gear larger). This weakens the pinion gear making it more prone to failure.
As for intake manifolds, if the ports on the intake manifold are larger than the ports in the heads, the abrupt change in size causes excessive turbulence in the intake port.This may result in a power loss instead ofthe expected gain. If you want to use such a combination, port matching work is needed.
Old 12-19-2008, 10:20 PM
z28rob18's Avatar
if you doin heads and cam look into advanced inductions they do some great work and hav alot of very impressive results!
Old 12-22-2008, 10:18 AM
whammer3024's Avatar
ROTM Winner
ummm...doing heads and cam can make the car less streetable and will effect mileage as well. and lloyd elliott does great work with heads and stuff as well
Old 12-23-2008, 12:33 AM
Skippysnax's Avatar
how much do the dragon heads cost?
Old 12-23-2008, 12:51 PM
ROTM Winner
call or email the guy there and ask him. tell him what you want from the car and he can set it up for you
Old 12-24-2008, 08:00 PM
95slvrZ28's Avatar
Ya, you're going to want to e-mail Pete, I'm not going to quote prices from him without his permission.
Old 12-27-2008, 02:38 AM
Skippysnax's Avatar
solid thanks guys il check it out.
princesid84
05-04-2013 01:56 AM
AMP3D
03-22-2012 11:41 AM
albo1989
07-16-2010 10:54 AM
jc1047
12-30-2009 08:52 AM
jimidude87
03-26-2007 02:08 PM
Quick Reply: Intake Manifold
