LT1/LT4 Tech 1993-1997
Idleing/misfireing
Old Feb 7, 2008 | 05:49 PM
Silkyslim408's Avatar
Default Idleing/misfireing
I have a 94 z28....I recently did a head job and car was running GREAT ! ! ! Now all of a sudden one day i got in and drove it and when i was at a light it was running ROUGH.... motor was shakin so bad made my exaust rattle.... ANy suggestions????
Old Feb 7, 2008 | 06:42 PM
libertyforall1776's Avatar
Default RE: Idleing/misfireing
Maybe it caught a cold? ;-)
Have you tested the fuel-pressure recently?
Old Feb 7, 2008 | 08:01 PM
If the check engine lite is lit take care of the trouble codes first. If not, the ignition would be the first thing to look at. Check or replace plugs an wires for a start, and then look for other possibilities, like ignition coil module and ignition coil. The optispark would be the next choice, but due to the cost, check out the various sensors (MAF, IAT, ECT, O2). Then check the FI system,(Fuel Pressure & pressure reg &verify all injectors are firing. Finally take a good look at the Optispark.
Old Feb 7, 2008 | 11:00 PM
95slvrZ28's Avatar
Pete, you should make a "Pete's Guide to Ignition Problems" and sticky it. Have a little guide of all things to check and possibly replace to solve the problem. This question gets asked far too often, and you're the man when it comes to it. Then when the question gets asked because people don't look at the stickies, we can just link them...c'mon
Old Feb 14, 2008 | 11:51 PM
Ok thanx for all the good information ! ! ! !
superROBZ
Dec 1, 2010 08:17 AM
Too
Jan 14, 2008 03:37 PM
jml317
82-92 V8 Tech
Dec 10, 2007 07:53 PM
jhop16
May 11, 2007 06:55 AM
jhop16
Jan 7, 2007 08:30 PM
