LT1/LT4 Tech 1993-1997
Zerk fittings Chasis Grease 1997 Z-28
Old Feb 13, 2008 | 01:54 PM
DrRuckus13's Avatar
Default Zerk fittings Chasis Grease 1997 Z-28
I was advised to keep up with "Chasis Greasing" from my mechnic because the car tends to squeek from normal driving. They said the suspension is still good but it sure makes alot if noises from bumps and dips. My question is the owners manual says to grease the chasis and the dealersalso recomend itbut I can't find any Zerk Fittings for a grease gun??? Do they even have them on a 1997 Z? Thanks.
Old Feb 14, 2008 | 03:57 PM
DrRuckus13's Avatar
Default RE: Zerk fittings Chasis Grease 1997 Z-28
* NUDGE *
Was this a stupid question or is greasing not important. No one in here has a comment?[&:]
Old Feb 14, 2008 | 04:40 PM
Lower ball joints. Take the front wheels off an you will see them. There are only two grease fittings on the whole car. If the joints were replaced with permanently lubed type, then there will be no fittings.
Old Feb 14, 2008 | 04:56 PM
libertyforall1776's Avatar
Pete, do you have any opinion on which is better -- grease fittings or permanently sealed, and why?
TIA
ORIGINAL: z28pete
Old Feb 15, 2008 | 04:16 PM
I prefer the sealed ones, especially the good quality ones,because I am lazy. In the 4th gen Camaro it is such a pain to get to the fittings that many people don't know or bother to grease them. However; if you do a lot of driving on sloppy road conditions, the erasable ones are probably better since all dirt an moisture is blown out when new grease is forced in.
camaroteen82
Apr 27, 2014 09:33 PM
big/sbc
Jun 2, 2012 03:21 PM
steelhorse
Dec 17, 2009 06:04 AM
KJK
Jan 7, 2007 07:05 PM
