i think i hate this car
#52
Were they spun? That's what the awful scraping/squeaking noise kinda sounded like.
Why does that question sound so familiar?
And did you replace the bearings, or just inspect the old ones?
#53
ya they spun i grabbed a hold of them and was able to shake the rods around and yes i replaced the bearings... they were cheap aluminum bearings this time im going to get chromoly ones and im going to just replace them all
#55
he has the tranny lose the pan off the connecting rods disconnected, i would say get the crank out and have it checked and turned if needed at a shop and get the correct size bearings for the turn.
#56
That would be the best way to go whether you see damage or not, then at least you know what dimensions you're dealing with. Any chance the engine/crank had already been worked on, and you put in stock bearings but the crank wanted undersized? Did you see any size stampings on the backs of the bearings?
#57
Or any stamps on the rod caps? Most guys will stamps the rods and caps with a number to make sure they keep them together as sets.
Dead give-away that the bottom end had been worked on previously.
Definitely need to take out the crank and have it inspected/ground. Even a slight gouge or burr will destroy the new bearings in just a few minutes.
On the bright side, you are getting more knowledge about the LT1 powertrain than 99% of other guys who replace an opti. <--I'm sorry, I couldn't help myself.
