LT1/LT4 Tech 1993-1997
hot when cold
Old Dec 7, 2006 | 01:33 PM
94Z28interceptor's Avatar
Default hot when cold
i noticed this a while ago, but since its getting cold again ive noticed that when the air is colder, my temp sensor says im running a little warmer than when the air is warm.. could this just be a faulty temp reading because of the extreme change of temp from the air to the engine?? it stays around 210 when warm. it doesnt run real hot cold, right around 225. i was just wondering thanks
Old Dec 7, 2006 | 02:39 PM
shnormo's Avatar
Default RE: hot when cold
The colder the ambient air is outside, the hotter the motor will run. Since the air is denser (and the car doesn't measure density) there is more air in the air to fuel mixture. The result is a lean setting.
luciora
Apr 11, 2013 11:17 AM
iLL95
Oct 12, 2011 10:32 AM
ladiesman2684
Mar 1, 2010 06:00 PM
jetmechvf24
Apr 15, 2009 07:52 PM
camaromanv6
Mar 11, 2009 10:20 AM
