LT1/LT4 Tech 1993-1997
heater question
Old Nov 12, 2007 | 07:04 PM
kyleb's Avatar
Default heater question
i have no heater in my camaro air blows but its just a fan er somthin...
i have papers that say that the heater hoses are cracking badly. these papers that say that, are kinda old so i dont know if that might have been fixed already er not.
im not leakin any coolant that i can tell so that would kinda eliminate the whole cracking badly thing wouldnt it?
i am going to check the core before i take the hoses off is there any thing i should do before i go and pull the core and is there any tips or help i can get on doing that...all information given is welcome thank you
kyle
Old Nov 12, 2007 | 11:51 PM
Default RE: heater question
From a cold engine, does your engine temp rise at a steady rate and stay within the normal operating temp? If not, look at your thermostat first.
Old Nov 14, 2007 | 08:20 PM
kyleb's Avatar
ive changed that not long ago when it used to overheat so that should be fine...it was just changed
Old Nov 14, 2007 | 08:36 PM
02StanGT's Avatar
Heater core could be bypassed as well.
Old Nov 15, 2007 | 05:55 PM
kyleb's Avatar
what do you mean by bypassed? like flushed out to see if its cloged? please explain thank you so much for everyones help
Old Nov 15, 2007 | 08:02 PM
If the engine is properly warmed up and there is no heat, check the temperature of the coolant hoses going to the heater core, they should be at the same temperature as the large radiator hoses. If not there is no coolant flowing to the heater. There are several reasons:
1)The heater core is clogged, try to flush it out by forcing water through it with a garden hose.
2)The heater core is bypassed, as 02StangGT, mentioned. Check the hose/pipes from the heater: top hose goes to the engine, the bottom hose to the water pump,You may find them disconnected at the engine end, and a bypass hose going from the heater fitting on the engine to the heater fitting on the water pump.
3) Clogged flow restrict or. If the heater hoses appear to be properly connected, disconnect both ends of each hose and force water through them with a garden hose. One of the hoses may have a flow restrict or that can get gunked up and prevent water from flowing to the heater.
Old Nov 17, 2007 | 12:04 AM
kyleb's Avatar
ok thank u all.... pete i will try this all in the morning... i dont wanna freeze this winter
JoshMan
Jul 19, 2012 09:05 PM
77 kencraft
Nov 20, 2011 10:19 AM
Chrisd0729
Aug 28, 2011 12:01 AM
Tony67RS
Sep 3, 2010 08:03 AM
DarlingReject
Aug 9, 2010 08:21 PM
