Heater Core Question!!!
Old Aug 31, 2010 | 07:42 AM
Tony67RS's Avatar
Default Heater Core Question!!!
Does anybody have any experience or advice on how to go about replacing a heater core on a '67 RS Camaro? I am about to do so and I want to make sure everything goes smoothly...
Old Sep 1, 2010 | 07:53 PM
dynarider33's Avatar
Good luck. The easiest way is to remove the inner fender to access it.
Old Sep 1, 2010 | 09:48 PM
It's not that hard, I pulled mine out altogether. You get it out from under the dash. Remove the glovebox, then you'll be able to see the blower case that's bolted to the inside firewall. Get that unbolted and removed (you'll also need to disconnect any ducting), and the heater core will be right inside there. I believe my core had a keeper bracket holding it in place. Then as long as the heater hoses are off, the core will pull right out (with maybe a little wiggling involved too).
Old Sep 2, 2010 | 04:42 PM
Dont know what I was thinkin, I put mine all together new core, box and cover so I forgot the cover does not need to come off from the outside.
Old Sep 3, 2010 | 07:18 AM
Tony67RS's Avatar
No worries man, I still respect that you tried to help me. Everyone has a lapse of memory
Old Sep 3, 2010 | 08:03 AM
edog2's Avatar
May 2010 ROTM Winner
Make sure you get the seals also. I had everything and then had to wait on those. And I did have to unbolt the fender, didnt take it all the way off though. Just unbolted everything so I could get at some of the top bolts.
Chrisd0729
Aug 28, 2011 12:01 AM
TikesterD
Apr 30, 2011 08:26 PM
albo1989
Jul 26, 2010 05:16 PM
Thoreau
Jan 1, 2009 02:09 PM
samdogg1400
Sep 19, 2008 02:48 PM
