LT1/LT4 Tech 1993-1997
heater
Old 01-03-2010, 08:17 PM
catback's Avatar
will try
Old 01-03-2010, 10:01 PM
on mine the bleeder in the hose will not bleed unless the motor is running and the cap is on.
Old 01-05-2010, 10:31 PM
Mr_Exacto's Avatar
Did you try flushing the heater core? According to shobox.com, a clog in this system is the #1 cause for a no heat complaint on a 4th gen f-body http://shbox.com/1/4th_gen_tech2.html#heaterflush.
1) Remove the heater hoses at the water pump. This allows flushing of the hoses and the core.
2) Orient the hoses to keep all moisture off the optispark.
3) Using a garden hose, flush into one heater hose allowing the water to come out the other.
4) Do not use high pressure. The cooling system is only rated for 18 psi. Full hose pressure can be over 50 psi.
5) When the water looks clear, swap hoses, flushing into the other one.
6) Reverse a couple of times to help ensure a good flush.
7) Re-connect the hoses and refill/bleed the system.
Location of bleeder screws: http://shbox.com/1/bleeders.jpg
Old 01-14-2010, 05:18 PM
catback's Avatar
Default thanks
to all that helped with ideas.,airlock,now have heat and is doing fine fans kick on later, does any one know the temp that they are suppose to kick on,sitting idling ,up and down on temp put in new temp sensor
Shalamara
11-10-2011 10:35 PM
78_junker
07-10-2010 08:36 AM
71CamaroZ28
07-23-2009 11:20 PM
TheGrimReaper73
11-03-2008 04:13 PM
dhighway
01-12-2008 07:28 PM
Quick Reply: heater
